Saltar al contenido principal
HP 8 1401 Front-Facing Camera Replacement
Qué necesitas
  1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Front-Facing Camera Replacement: paso 2, imagen 1 de 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Front-Facing Camera Replacement: paso 3, imagen 1 de 2 HP 8 1401 Front-Facing Camera Replacement: paso 3, imagen 2 de 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: paso 4, imagen 1 de 1
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
  5. HP 8 1401 Front-Facing Camera Replacement: paso 5, imagen 1 de 2 HP 8 1401 Front-Facing Camera Replacement: paso 5, imagen 2 de 2
    • Lift the front-facing camera out of the tablet.
  6. HP 8 1401 Front-Facing Camera Replacement: paso 6, imagen 1 de 1
    • After the front-facing camera has been removed, the tablet should look like this.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 138
