Saltar al contenido principal
HP 8 1401 Battery Replacement
Qué necesitas
  1. HP 8 1401 Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Battery Replacement: paso 2, imagen 1 de 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Battery Replacement: paso 3, imagen 1 de 2 HP 8 1401 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Battery Replacement, Battery: paso 4, imagen 1 de 2 HP 8 1401 Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Using a spudger or your fingers, disconnect the power cable by sliding the connector out of the socket on the motherboard.
  5. HP 8 1401 Battery Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    Comprar
    • Using a plastic card or a nylon spudger, carefully pry the battery from the adhesive on the tablet.
    • Do not use a metal spudger, which may damage/puncture the battery and pose a hazard.
  6. HP 8 1401 Battery Replacement: paso 6, imagen 1 de 1
    • Once the battery is removed the battery and tablet should look like this.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 884
