Saltar al contenido principal
HP 7 Plus 1302 Charging Port Replacement
Qué necesitas
  1. HP 7 Plus 1302 Charging Port Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Charging Port Replacement: paso 2, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 2, imagen 2 de 2
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Charging Port Replacement: paso 3, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 3, imagen 2 de 2
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Charging Port Replacement, Battery: paso 4, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement, Battery: paso 4, imagen 2 de 2
    • Push out the battery connector using the spudger.
    • Swing the battery connector clear of the connector socket.
  5. HP 7 Plus 1302 Charging Port Replacement: paso 5, imagen 1 de 1
    • Lift the battery from the device.
  6. HP 7 Plus 1302 Charging Port Replacement, Motherboard: paso 6, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement, Motherboard: paso 6, imagen 2 de 2
    • Pry the connector that attaches the front and back camera with a metal spudger.
  7. HP 7 Plus 1302 Charging Port Replacement: paso 7, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 7, imagen 2 de 2
    • Pull the camera from the connectors.
  8. HP 7 Plus 1302 Charging Port Replacement: paso 8, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 8, imagen 2 de 2
    • Identify the three T5x1mm screws and remove them with a Phillips #000
  9. HP 7 Plus 1302 Charging Port Replacement: paso 9, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Unplug the connector with the tweezers.
    • Remove the tape.
  10. HP 7 Plus 1302 Charging Port Replacement: paso 10, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 10, imagen 2 de 2
    • Flip the ZIF connector with the metal spudger.
    • Pull the ribbon connector out.
  11. HP 7 Plus 1302 Charging Port Replacement: paso 11, imagen 1 de 3 HP 7 Plus 1302 Charging Port Replacement: paso 11, imagen 2 de 3 HP 7 Plus 1302 Charging Port Replacement: paso 11, imagen 3 de 3
    • Pull the orange tape with the tweezers.
    • Flip the ZIF connector with the spudger.
    • Pull the ribbon connector with the tweezers.
  12. HP 7 Plus 1302 Charging Port Replacement: paso 12, imagen 1 de 1
    • Remove the gray tape below the ribbon connector.
  13. HP 7 Plus 1302 Charging Port Replacement: paso 13, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 13, imagen 2 de 2
    • Flip the ZIF connector.
    • Pull the ribbon connector out with the tweezers.
  14. HP 7 Plus 1302 Charging Port Replacement: paso 14, imagen 1 de 2 HP 7 Plus 1302 Charging Port Replacement: paso 14, imagen 2 de 2
    • Pull the circuit board off.
  15. HP 7 Plus 1302 Charging Port Replacement, Charging Port: paso 15, imagen 1 de 1
    • Desolder the four points on the charging port using the soldering iron.
    • Soldering iron will be hot be careful.
    • For more instructions about how to use the Soldering iron click here.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 1-4, Baechle Spring 2017 Miembro de IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 446
