Introducción
Changing the battery may be necessary if the device wont power up, or doesn't seem to hold a charge anymore. The most challenging step to changing the battery is removing the back cover. Acquiring the tools listed (or similar) are absolutely necessary for a complication free battery replacement.
Qué necesitas
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Push out the battery connector using the spudger.
Swing the battery connector clear of the connector socket.
To reassemble your device, follow these instructions in reverse order. Use new double sided tape to secure the new battery.
Una persona más ha completado esta guía.
