Introducción
This guide will show you how to remove and replace the cameras on your HP 7 Plus 1301. This will include opening the back cover of your tablet, disconnecting both cameras and removing them. This guide will show you a detailed step by step process even if you have no experience in tablets and electronics. Please click on the links below to purchase the necessary tools needed for this project.
Qué necesitas
Using a Torx T5 screwdriver, remove the 3mm screws on all four corners of the device.
Gently push the tabs on both sides until the front camera is loose.
Using your blunt tweezers, lift the front camera gently away from the board.
Una persona más ha completado esta guía.
