Saltar al contenido principal
HP 7 1800 Speaker Replacement
Qué necesitas
  1. HP 7 1800 Speaker Replacement, Remove the back panel: paso 1, imagen 1 de 2 HP 7 1800 Speaker Replacement, Remove the back panel: paso 1, imagen 2 de 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Speaker Replacement, Remove the battery: paso 2, imagen 1 de 3 HP 7 1800 Speaker Replacement, Remove the battery: paso 2, imagen 2 de 3 HP 7 1800 Speaker Replacement, Remove the battery: paso 2, imagen 3 de 3
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
  3. HP 7 1800 Speaker Replacement, Desolder the speaker wires: paso 3, imagen 1 de 1
    • Desolder the two leads of the speaker wire that are connected to the motherboard.
  4. HP 7 1800 Speaker Replacement, Remove the speaker: paso 4, imagen 1 de 1
    • Using tweezers, gently pull the speaker off of the metal plate.
    • The speaker is held onto the metal plate with light adhesive. It will require a little force to peel off.
Conclusión
TMD
Miembro Desde 01/21/15
765 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-1, Brown Winter 2015 Miembro de USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 212
