Introducción
The motherboard could be the root of many problems of your HP 7 1800. This guide will aid you in replacing the motherboard.
Qué necesitas
Carefully insert a Spudger into one of the corners of the tablet.
Slide the Spudger along the edge popping the tabs out along the way.
Slide the Spudger under the battery to lift it off the adhesive.
Gently pull the cable connection from the motherboard using tweezers.
Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
Remove the following 7 screws:
Six 4.17mm Phillips #00 around the motherboard.
One 2.67mm Phillips #00 next to the front facing camera.
Gently pry the front facing camera plug up and off of the motherboard.
Un comentario
After replacing the motherboard, will is act as a brand new tablet upon next boot? Will the OS and everything already be installed? Or is the main memory module elsewhere in the tablet?
