Saltar al contenido principal
HP 7 1800 Battery Replacement
Qué necesitas
  1. HP 7 1800 Battery Replacement, Remove the back panel: paso 1, imagen 1 de 2 HP 7 1800 Battery Replacement, Remove the back panel: paso 1, imagen 2 de 2
    • Carefully insert a Spudger into one of the corners of the tablet.
    • Slide the Spudger along the edge popping the tabs out along the way.
    • Be careful not to break the tabs.
  2. HP 7 1800 Battery Replacement, Remove the battery: paso 2, imagen 1 de 3 HP 7 1800 Battery Replacement, Remove the battery: paso 2, imagen 2 de 3 HP 7 1800 Battery Replacement, Remove the battery: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Slide the Spudger under the battery to lift it off the adhesive.
    • Gently pull the cable connection from the motherboard using tweezers.
Conclusión
Una persona más ha completado esta guía.
TMD
Miembro Desde 01/21/15
765 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 4-1, Brown Winter 2015 Miembro de USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Miembros
14 Guías creadas
2 comentarios
This is the OEM Replacement Battery, 740963-001, HP Spare: 739691-001, but you can find an OEM replacement the fits and works perfectly will be the Dell Venue 7 battery -17.29Wh 4550 mAh P708 DHM0J and half the price.
Santiago - Contestar
Santiago is wrong, you cannot use the Dell battery because the connectors are different sizes. Now I am stuck with a Dell battery that does not fit and have to order the hp battery. Also you cannot de-pin the two and re-pin, the brass fitting on the wire are bigger and will not fit in the hp connector. DON NOT TRY USING THE DELL IN PLACE OF THE HP.
Glenn Wemmer - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 3,373
