Qué necesitas
HP310-1037 Touchsmart PC with a dead hard drive. The hard drive is located behind the stand cover.
Lay the PC flat on the front to gain access to the stand cover
Remove the single screw that holds the stand cover to the chassis with a flat tip screwdriver
Remove the four Torx/Flathead screws securing the stand.
Lift the bottom part of the stand upwards, and it will come off.
Remove the four Torx/Flathead screws securing the back cover.
Also unscrew the two captive Philips screws securing the disc drive, as these two screws also secure the back cover.
Remove the seven silver Torx/Flathead screws securing the metal shield.
Remove the single black Torx/Flathead screw securing the metal shield.
Remove the cables strung through the shield.
Pull up on the shield to remove it.
Remove the two Torx/Flathead screws securing the fan.
Pull up on the fan connector to remove it.
Lift the fan to remove it.
Remove the six Philips screws securing the heatsink assembly to the motherboard.
Carefully lift the heatsink. If it won't come off, twist it as you pull it off. If it still won't come off, pull harder.
Remove all attached connectors from the motherboard.
Remove the four remaining screws securing the motherboard. You're done!
Una persona más ha completado esta guía.
