Saltar al contenido principal
HP 2000 - 2D22DX RAM Replacement
Qué necesitas
  1. HP 2000 - 2D22DX RAM Replacement, Battery: paso 1, imagen 1 de 2 HP 2000 - 2D22DX RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX RAM Replacement: paso 2, imagen 1 de 2 HP 2000 - 2D22DX RAM Replacement: paso 2, imagen 2 de 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX RAM Replacement, RAM: paso 3, imagen 1 de 2 HP 2000 - 2D22DX RAM Replacement, RAM: paso 3, imagen 2 de 2
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX RAM Replacement: paso 4, imagen 1 de 2 HP 2000 - 2D22DX RAM Replacement: paso 4, imagen 2 de 2
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
  5. HP 2000 - 2D22DX RAM Replacement: paso 5, imagen 1 de 3 HP 2000 - 2D22DX RAM Replacement: paso 5, imagen 2 de 3 HP 2000 - 2D22DX RAM Replacement: paso 5, imagen 3 de 3
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
  6. HP 2000 - 2D22DX RAM Replacement: paso 6, imagen 1 de 1
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
Conclusión
5 personas más completaron esta guía.
Conor Most
Miembro Desde 04/14/14
2,687 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-40, Maness Spring 2014 Miembro de Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 3,641
