Saltar al contenido principal
HP 2000 - 2D22DX Optical Drive Replacement
Qué necesitas
  1. HP 2000 - 2D22DX Optical Drive Replacement, Battery: paso 1, imagen 1 de 2 HP 2000 - 2D22DX Optical Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
  2. HP 2000 - 2D22DX Optical Drive Replacement: paso 2, imagen 1 de 2 HP 2000 - 2D22DX Optical Drive Replacement: paso 2, imagen 2 de 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
  3. HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 HP 2000 - 2D22DX Optical Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Loosen the Phillips #00 screw securing the RAM compartment cover.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
  4. HP 2000 - 2D22DX Optical Drive Replacement: paso 4, imagen 1 de 2 HP 2000 - 2D22DX Optical Drive Replacement: paso 4, imagen 2 de 2
    • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
    • When unclipped completely, pull the compartment door out and away from the chassis.
  5. HP 2000 - 2D22DX Optical Drive Replacement: paso 5, imagen 1 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 5, imagen 2 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 5, imagen 3 de 3
    • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
    • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
    • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  6. HP 2000 - 2D22DX Optical Drive Replacement: paso 6, imagen 1 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 6, imagen 2 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 6, imagen 3 de 3
    • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
    • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
  7. HP 2000 - 2D22DX Optical Drive Replacement: paso 7, imagen 1 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 7, imagen 2 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 7, imagen 3 de 3
    • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
    • Lift the hard drive out and away from its socket in the plastic chassis.
  8. HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: paso 8, imagen 1 de 2 HP 2000 - 2D22DX Optical Drive Replacement, Optical Drive: paso 8, imagen 2 de 2
    • Locate the Phillips-head screw on the left side of the hard drive recess, indicated by a red circle.
    • Use a #00 Phillips head screwdriver to remove the small screw. Consider using a magnetized screwdriver.
  9. HP 2000 - 2D22DX Optical Drive Replacement: paso 9, imagen 1 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 9, imagen 2 de 3 HP 2000 - 2D22DX Optical Drive Replacement: paso 9, imagen 3 de 3
    • Once the securing screw is removed, the optical drive can be pulled from its slot easily.
    • Use your fingers to pull the optical drive away slowly from its position in the plastic chassis.
    • The optical drive should slide out very easily. If you fell resistance, do not pull too hard. Something may be caught, and you might damage the optical drive's connections.
Conclusión
3 personas más completaron esta guía.
Conor Most
Miembro Desde 04/14/14
2,687 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 3-40, Maness Spring 2014 Miembro de Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 1,620
