Saltar al contenido principal
HP 17-x173dx CPU Cooling Fan Replacement
Qué necesitas
  1. HP 17-x173dx CPU Cooling Fan Replacement, Battery: paso 1, imagen 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement, Battery: paso 1, imagen 2 de 2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx CPU Cooling Fan Replacement: paso 2, imagen 1 de 1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx CPU Cooling Fan Replacement: paso 3, imagen 1 de 3 HP 17-x173dx CPU Cooling Fan Replacement: paso 3, imagen 2 de 3 HP 17-x173dx CPU Cooling Fan Replacement: paso 3, imagen 3 de 3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: paso 4, imagen 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: paso 4, imagen 2 de 2
    • Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
    • Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
  5. HP 17-x173dx CPU Cooling Fan Replacement: paso 5, imagen 1 de 3 HP 17-x173dx CPU Cooling Fan Replacement: paso 5, imagen 2 de 3 HP 17-x173dx CPU Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
    • Disconnect the power cable.
  6. HP 17-x173dx CPU Cooling Fan Replacement: paso 6, imagen 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Remove the CPU cooling fan.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 407
