Saltar al contenido principal
HP 17-x116dx Space bar key Replacement
Qué necesitas
  1. HP 17-x116dx Space bar key Replacement, Space Bar Key: paso 1, imagen 1 de 1
    • Locate the spacebar key.
  2. HP 17-x116dx Space bar key Replacement: paso 2, imagen 1 de 1
    • At the edge of the space bay key use a spudger to help with the removal.
  3. HP 17-x116dx Space bar key Replacement: paso 3, imagen 1 de 1
    • Slide the spudger under the spacebar key.
  4. HP 17-x116dx Space bar key Replacement: paso 4, imagen 1 de 1
    • The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
  5. HP 17-x116dx Space bar key Replacement: paso 5, imagen 1 de 1
    • During this point you can carefully take off the spacebar key.
  6. HP 17-x116dx Space bar key Replacement: paso 6, imagen 1 de 1
    • you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
  7. HP 17-x116dx Space bar key Replacement: paso 7, imagen 1 de 1
    • Dust off any dirt that could be under there.
  8. HP 17-x116dx Space bar key Replacement: paso 8, imagen 1 de 1
    • The lower edge of the keyboard has two plastic notches on either side.
  9. HP 17-x116dx Space bar key Replacement: paso 9, imagen 1 de 1
    • slide the bracket into the space below the spacebar to carefully place it back.
  10. HP 17-x116dx Space bar key Replacement: paso 10, imagen 1 de 1
    • The Spacebar key will be working once you can press down and it will type a space.
Conclusión
Liliana Chuc
Miembro Desde 03/22/18
281 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 25
Todo El Tiempo: 936
