Saltar al contenido principal
HP 17-x027ds LCD Screen Replacement
Qué necesitas
  1. HP 17-x027ds LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 3 HP 17-x027ds LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 3 HP 17-x027ds LCD Screen Replacement, LCD Screen: paso 1, imagen 3 de 3
    • Open the laptop so you can see the screen.
    • Remove the bezel with firm, constant pressure to create a slight gap between the bezel and screen (plastic outlining of screen) with a plastic opening tool.
    • Remove the bezel by starting on the sides of the screen and lastly removing the top outlining.
    • When removing the bezel, be cautious not to use too much force or else you will damage the screen. Apply just enough pressure to create a gap between the bezel and screen.
  2. HP 17-x027ds LCD Screen Replacement: paso 2, imagen 1 de 3 HP 17-x027ds LCD Screen Replacement: paso 2, imagen 2 de 3 HP 17-x027ds LCD Screen Replacement: paso 2, imagen 3 de 3
    • Lift the bezel off the screen to see the outlines of the LCD screen.
    • Remove the four black 3mm screws in each corner of the screen with a JIS #1 screwdriver.
    • Remove the two silver 4mm screws located at the top of the screen with a JIS #1 screwdriver.
  3. HP 17-x027ds LCD Screen Replacement: paso 3, imagen 1 de 2 HP 17-x027ds LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the LCD screen and place it on the keyboard.
    • Disconnect the video cable to completely detach the LCD screen.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 645
