Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
This guide will assist you in replacing the battery. You will need to replace the battery if it is not able to charge when plugged in.
  1. Flip the laptop so you can see the serial number and the four 7mm screws in all the corners. Click the hinges by pushing them inward, which are located at the top of the laptop. Remove the battery by pulling it out.
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top of the laptop.
    • Remove the battery by pulling it out.
  2. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
Conclusión
Bryan Garza
Miembro Desde 17/09/18
92 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 146
