Introducción
The RAM is an extremely fast type of computer memory which temporarily stores all information of your PC needs now and in the near future. If your computer is running very slow or installing things fail multiple times, then you may have RAM damage. This guide will show you steps to replacing the RAM.
Herramientas
Partes
No se especificaron partes.
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
To take off the RAM, pull out the circled taps in the direction of the arrows on the pictures.
Una persona más ha completado esta guía.
