Saltar al contenido principal
Introducción
Use this guide to replace the hard drive in your HP 17-bs049dx.
Partes
No se especificaron partes.
  1. To remove the battery, simply push the tabs towards each other.
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. Pull outwards on the disk reader to remove from main frame. This removal will require force.
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. Lift back panel to access internal components.
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  7. Lift rubber black tabs located on the hard drive upwards. Disconnect hard drive from motherboard by pulling towards you.
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
Conclusión
7 personas más completaron esta guía.
This was SPOT ON! After searching high and low all over the fricken INTERWEBS for a decent manual, I landed here on your guide and am VERY thankful! KUDOS to you for sharing it!
John Hart - Contestar
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
Stephanie Rose Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 16
Ultimos 30 días: 72
Todo El Tiempo: 2,537
