Saltar al contenido principal
HP 15-r137wm TouchSmart Screen Replacement
Qué necesitas
  1. HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: paso 1, imagen 1 de 3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: paso 1, imagen 2 de 3 HP 15-r137wm TouchSmart Screen Replacement, Front Panel Assembly: paso 1, imagen 3 de 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Screen Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Screen Replacement: paso 3, imagen 1 de 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Screen Replacement: paso 4, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement: paso 4, imagen 2 de 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart Screen Replacement, Keyboard: paso 5, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement, Keyboard: paso 5, imagen 2 de 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart Screen Replacement: paso 6, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement: paso 6, imagen 2 de 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart Screen Replacement, CD Drive: paso 7, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement, CD Drive: paso 7, imagen 2 de 2
    • Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
  8. HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: paso 8, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement, Cooling Fan: paso 8, imagen 2 de 2
    • Locate the small connection on the motherboard and disconnect it by slowly pulling it away from the motherboard.
    • Slowly disconnect the cable as the wires are very small and fragile
  9. HP 15-r137wm TouchSmart Screen Replacement: paso 9, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement: paso 9, imagen 2 de 2
    • Remove the three (3) 2.5mm by 3.5mm Phillips #0 screws from the fan.
  10. HP 15-r137wm TouchSmart Screen Replacement: paso 10, imagen 1 de 1
    • Remove the cooling fan from the housing carefully.
    • The fan may be connected to the small foam screen. Pull gently to release it.
  11. HP 15-r137wm TouchSmart Screen Replacement, Screen: paso 11, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement, Screen: paso 11, imagen 2 de 2
    • Remove the 5.5mm Phillips #0 screw.
  12. HP 15-r137wm TouchSmart Screen Replacement: paso 12, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement: paso 12, imagen 2 de 2
    • Gently pull and slide the video card out of its connector.
  13. HP 15-r137wm TouchSmart Screen Replacement: paso 13, imagen 1 de 2 HP 15-r137wm TouchSmart Screen Replacement: paso 13, imagen 2 de 2
    • Lift up tape, and then remove the power cable from its connector.
  14. HP 15-r137wm TouchSmart Screen Replacement: paso 14, imagen 1 de 3 HP 15-r137wm TouchSmart Screen Replacement: paso 14, imagen 2 de 3 HP 15-r137wm TouchSmart Screen Replacement: paso 14, imagen 3 de 3
    • Remove all four (4) 5.5mm Phillips #0 screws.
    • Remove the one (1) 2.5mm Phillips #0 screw.
    • Since all of the screws are now removed, the screen will begin to fall off on its own. make sure the screen is supported before removal.
  15. HP 15-r137wm TouchSmart Screen Replacement: paso 15, imagen 1 de 1
    • The screen can now be lifted out of place from the laptop.
Conclusión
2 personas más completaron esta guía.
Ross B Jacques
Miembro Desde 10/18/17
881 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 665
