Saltar al contenido principal
HP 15-r137wm TouchSmart Front Panel Assembly Replacement
Qué necesitas
  1. HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: paso 1, imagen 1 de 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: paso 1, imagen 2 de 3 HP 15-r137wm TouchSmart Front Panel Assembly Replacement, Front Panel Assembly: paso 1, imagen 3 de 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: paso 3, imagen 1 de 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart Front Panel Assembly Replacement: paso 4, imagen 1 de 2 HP 15-r137wm TouchSmart Front Panel Assembly Replacement: paso 4, imagen 2 de 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
Conclusión
2 personas más completaron esta guía.
Ross B Jacques
Miembro Desde 10/18/17
881 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 448
