Introducción
Is your DVD-ROM cracked or smashed? Or it can not open? Well, you are in luck, this replacement guide will help aid you replace the DVD-ROM. This guide is helpful if the DVD-ROM doesn’t work.
This guide will walk you through step by step on how to replace the DVD-ROM. Is the DVD-ROM on your computer not working and you found out it costs a lot to have them fixed? Well you are in luck. The following guide consists of the steps to remove the DVD-ROM from the computer while also showing you the prerequisite steps to be able to remove the DVD-ROM. This guide allows you to replace your DVD-ROM yourself for free rather than having to pay someone to do it.
Qué necesitas
Flip over the device so that the bottom is facing you.
Remove the screws using the Phillips #0 screwdriver.
Una persona más ha completado esta guía.
