Saltar al contenido principal
HP 15-g020dx Keyboard Replacement
Qué necesitas
  1. HP 15-g020dx Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the laptop over so that the bottom is facing you.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g020dx Keyboard Replacement: paso 2, imagen 1 de 1
    • Place your finger on the left latch and slide it towards the center of the laptop to remove the battery.
  3. HP 15-g020dx Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the laptop.
  4. HP 15-g020dx Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Use the plastic opening tool to lift the panel with the keyboard.
  5. HP 15-g020dx Keyboard Replacement: paso 5, imagen 1 de 1
    • Take the keyboard and the section of the panel surrounding the keyboard apart.
  6. HP 15-g020dx Keyboard Replacement: paso 6, imagen 1 de 2 HP 15-g020dx Keyboard Replacement: paso 6, imagen 2 de 2
    • Lift the flip covering the connection port and remove the connecting strip to detach the keyboard from the motherboard.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 19
Todo El Tiempo: 386
