Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide will walk you through step by step on how to replace the speakers on the HP 15-g010dx laptop. You will need about 10-15 minutes to do this replacement. Before you embark make sure that you have your replacement speakers ready to install.
Partes
No se especificaron partes.
  1. Slide the latch towards the center of the laptop so the unlock emblem appears.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. Place your finger on the left latch and slide it towards the center of the laptop.
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. Pull on the battery to remove.
    • Pull on the battery to remove.
  4. Remove the two 5 mm screws with the Phillips #00 screwdriver.
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. Using the tool of your choice, gently pry up on the top of the keyboard.
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. Release the top of the keyboard.
    • Release the top of the keyboard.
  8. Remove the ZIF connector that connects the laptop to the keyboard cable.
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
    • Using the Phillips #00 screwdriver, remove the 5 millimeter screws that are visible.
  10. Using the spudger, remove the two rubber feet that are located near the battery. Using the spudger, remove the two rubber feet that are located near the battery.
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. Now remove the two Phillips screws that are located below the rubber feet. Now remove the two Phillips screws that are located below the rubber feet.
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. Remove the optical drive by pulling it out by hand. Remove the optical drive by pulling it out by hand. Remove the optical drive by pulling it out by hand.
    • Remove the optical drive by pulling it out by hand.
  13. Remove the two Phillips screws inside the optical drive housing.
    • Remove the two Phillips screws inside the optical drive housing.
  14. Disconnect the power button ribbon cable by lifting the connector.
    • Disconnect the power button ribbon cable by lifting the connector.
  15. Disconnect the touch pad ribbon cable by lifting up on the connector. Disconnect the touch pad ribbon cable by lifting up on the connector. Disconnect the touch pad ribbon cable by lifting up on the connector.
    • Disconnect the touch pad ribbon cable by lifting up on the connector.
  16. Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was. Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was. Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
    • Now remove the screws indicated by an arrow stamped into the metal, located where the keyboard was.
  17. Take the metal spudger and gently insert in between the palm rest and the body.
    • Take the metal spudger and gently insert in between the palm rest and the body.
  18. Work the spudger in small increments around the palm rest while lifting it up in the air.
    • Work the spudger in small increments around the palm rest while lifting it up in the air.
  19. Carefully remove the palm rest and flip it over. Carefully remove the palm rest and flip it over. Carefully remove the palm rest and flip it over.
    • Carefully remove the palm rest and flip it over.
  20. Lift up on the speaker connectors to unplug the speaker cables. Lift up on the speaker connectors to unplug the speaker cables.
    • Lift up on the speaker connectors to unplug the speaker cables.
  21. Remove the screws that are securing the speakers. Remove the screws that are securing the speakers.
    • Remove the screws that are securing the speakers.
  22. Remove the speakers. Remove the speakers.
    • Remove the speakers.
Linea de Meta
2 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 205
