Saltar al contenido principal
HP 15-f162dx RAM Replacement
Qué necesitas
  1. HP 15-f162dx RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin the repair.
  2. HP 15-f162dx RAM Replacement: paso 2, imagen 1 de 1
    • Use a small Phillips screwdriver to remove the four screws from the RAM cover. Remove the RAM cover.
    • Remove it at an angle and not straight up so you don't damage the socket.
  3. HP 15-f162dx RAM Replacement: paso 3, imagen 1 de 1
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • The RAM will pop up by a few millimeters.
    • Repeat steps in reverse order to reassemble the computer with new RAM
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 387
