Saltar al contenido principal
HP 15-f033wm Screen Replacement
Qué necesitas
  1. HP 15-f033wm Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Screen Replacement: paso 2, imagen 1 de 2 HP 15-f033wm Screen Replacement: paso 2, imagen 2 de 2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Screen Replacement: paso 3, imagen 1 de 2 HP 15-f033wm Screen Replacement: paso 3, imagen 2 de 2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Screen Replacement: paso 4, imagen 1 de 2 HP 15-f033wm Screen Replacement: paso 4, imagen 2 de 2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Screen Replacement: paso 5, imagen 1 de 3 HP 15-f033wm Screen Replacement: paso 5, imagen 2 de 3 HP 15-f033wm Screen Replacement: paso 5, imagen 3 de 3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. HP 15-f033wm Screen Replacement, Screen: paso 6, imagen 1 de 1
    • After removing the battery, remove the bezel. Do this by prying it away from the faulty screen using the spudger.
    • Make sure screen is angles as far back as possible to fully remove the bottom hinges of the bezel without damaging the laptop.
  7. HP 15-f033wm Screen Replacement: paso 7, imagen 1 de 1
    • Remove the four 3 mm PH1 Phillips head screws in each corner of the screen, fastening the screen to the rest of the laptop.
  8. HP 15-f033wm Screen Replacement: paso 8, imagen 1 de 1
    • Gently remove the screen and place it on the keyboard.
  9. HP 15-f033wm Screen Replacement: paso 9, imagen 1 de 2 HP 15-f033wm Screen Replacement: paso 9, imagen 2 de 2
    • Remove the tape on top of the video cable.
    • Gently disconnect the video cable.
Conclusión
4 personas más completaron esta guía.
Aaron Chabot
Miembro Desde 10/17/17
620 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 1,502
