Saltar al contenido principal
HP 15-f009wm Motherboard Replacement
Qué necesitas
  1. HP 15-f009wm Motherboard Replacement, Battery: paso 1, imagen 1 de 2 HP 15-f009wm Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Motherboard Replacement: paso 2, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 2, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 2, imagen 3 de 3
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Motherboard Replacement: paso 3, imagen 1 de 2 HP 15-f009wm Motherboard Replacement: paso 3, imagen 2 de 2
    • Slide the battery out.
  4. HP 15-f009wm Motherboard Replacement, RAM: paso 4, imagen 1 de 3 HP 15-f009wm Motherboard Replacement, RAM: paso 4, imagen 2 de 3 HP 15-f009wm Motherboard Replacement, RAM: paso 4, imagen 3 de 3
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Motherboard Replacement: paso 5, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 5, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 5, imagen 3 de 3
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Motherboard Replacement: paso 6, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 6, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 6, imagen 3 de 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Motherboard Replacement, Hard Drive: paso 8, imagen 1 de 1
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Motherboard Replacement: paso 9, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 9, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 9, imagen 3 de 3
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Motherboard Replacement: paso 11, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 11, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 11, imagen 3 de 3
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Motherboard Replacement: paso 12, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 12, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 12, imagen 3 de 3
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Motherboard Replacement: paso 13, imagen 1 de 2 HP 15-f009wm Motherboard Replacement: paso 13, imagen 2 de 2
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Motherboard Replacement: paso 14, imagen 1 de 1
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Motherboard Replacement: paso 15, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 15, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 15, imagen 3 de 3
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Motherboard Replacement: paso 16, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 16, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 16, imagen 3 de 3
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Motherboard Replacement: paso 17, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 17, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 17, imagen 3 de 3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Motherboard Replacement: paso 18, imagen 1 de 2 HP 15-f009wm Motherboard Replacement: paso 18, imagen 2 de 2
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Motherboard Replacement: paso 19, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 19, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 19, imagen 3 de 3
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
  20. HP 15-f009wm Motherboard Replacement, Motherboard: paso 20, imagen 1 de 2 HP 15-f009wm Motherboard Replacement, Motherboard: paso 20, imagen 2 de 2
    • Remove the four 4mm Phillips #1 screws from the motherboard.
    • Lift the motherboard up from the computer.
    • There will be three wires connected underneath.
  21. HP 15-f009wm Motherboard Replacement: paso 21, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 21, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 21, imagen 3 de 3
    • Disconnect the speaker.
  22. HP 15-f009wm Motherboard Replacement: paso 22, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 22, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 22, imagen 3 de 3
    • Remove the display connection wire. Lift the connection straight up from the motherboard.
  23. HP 15-f009wm Motherboard Replacement: paso 23, imagen 1 de 3 HP 15-f009wm Motherboard Replacement: paso 23, imagen 2 de 3 HP 15-f009wm Motherboard Replacement: paso 23, imagen 3 de 3
    • Flip the motherboard over.
    • Disconnect the charging port wire from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Alex Birchler
Miembro Desde 02/14/18
1,008 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G2, Nance Spring 2018 Miembro de USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 1,499
