Saltar al contenido principal
HP 15-ef2025nr Fan Replacement
Qué necesitas
  1. HP 15-ef2025nr Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Fan Replacement: paso 2, imagen 1 de 2 HP 15-ef2025nr Fan Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Fan Replacement: paso 3, imagen 1 de 2 HP 15-ef2025nr Fan Replacement: paso 3, imagen 2 de 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Fan Replacement: paso 4, imagen 1 de 2 HP 15-ef2025nr Fan Replacement: paso 4, imagen 2 de 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Fan Replacement: paso 5, imagen 1 de 3 HP 15-ef2025nr Fan Replacement: paso 5, imagen 2 de 3 HP 15-ef2025nr Fan Replacement: paso 5, imagen 3 de 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Fan Replacement, Fan: paso 6, imagen 1 de 3 HP 15-ef2025nr Fan Replacement, Fan: paso 6, imagen 2 de 3 HP 15-ef2025nr Fan Replacement, Fan: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to pull the fan connector directly out of its motherboard socket.
    • Do not pull on the wires; they are very delicate.
  7. HP 15-ef2025nr Fan Replacement: paso 7, imagen 1 de 3 HP 15-ef2025nr Fan Replacement: paso 7, imagen 2 de 3 HP 15-ef2025nr Fan Replacement: paso 7, imagen 3 de 3
    • Remove the three 2 mm Phillips screws at the top corners and four o'clock position on the fan.
    • Remove the fan.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 205
