Saltar al contenido principal
HP 15-dy2702dx Keyboard Replacement
Qué necesitas
  1. HP 15-dy2702dx Keyboard Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Keyboard Replacement: paso 2, imagen 1 de 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Keyboard Replacement: paso 3, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 3, imagen 2 de 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Keyboard Replacement: paso 4, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 4, imagen 2 de 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Keyboard Replacement: paso 5, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 5, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 5, imagen 3 de 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Keyboard Replacement, Battery: paso 6, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement, Battery: paso 6, imagen 2 de 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Keyboard Replacement: paso 7, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 7, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 7, imagen 3 de 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
  8. HP 15-dy2702dx Keyboard Replacement, Trackpad: paso 8, imagen 1 de 1
    • Find the trackpad.
  9. HP 15-dy2702dx Keyboard Replacement: paso 9, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 9, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 9, imagen 3 de 3
    • Unscrew the two M2x6 Phillips screws securing the trackpad.
  10. HP 15-dy2702dx Keyboard Replacement: paso 10, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 10, imagen 2 de 2
    • Remove the metal bracket.
  11. HP 15-dy2702dx Keyboard Replacement: paso 11, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 11, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 11, imagen 3 de 3
    • Lift the black ribbon covering the screws.
    • Unscrew the top three M2x3 Phillips screws.
  12. HP 15-dy2702dx Keyboard Replacement: paso 12, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 12, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 12, imagen 3 de 3
    • Flip up the locking flap holding the trackpad ribbon in place.
    • Pull the ribbon straight out of its socket.
  13. HP 15-dy2702dx Keyboard Replacement: paso 13, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 13, imagen 2 de 2
    • Peel back the sticky black strip holding the trackpad in place.
  14. HP 15-dy2702dx Keyboard Replacement: paso 14, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 14, imagen 2 de 2
    • Remove the trackpad from the laptop.
  15. HP 15-dy2702dx Keyboard Replacement, SSD: paso 15, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement, SSD: paso 15, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement, SSD: paso 15, imagen 3 de 3
    • Locate the storage drive.
    • Unscrew the single screw holding the drive in place.
    • The screw is a M2x3 mm Phillips head screw.
  16. HP 15-dy2702dx Keyboard Replacement: paso 16, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 16, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 16, imagen 3 de 3
    • Grab the drive by its side and gently pull it out.
  17. HP 15-dy2702dx Keyboard Replacement, Fan: paso 17, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement, Fan: paso 17, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement, Fan: paso 17, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
  18. HP 15-dy2702dx Keyboard Replacement: paso 18, imagen 1 de 1
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
  19. HP 15-dy2702dx Keyboard Replacement: paso 19, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 19, imagen 2 de 2
    • Gently lift the fan to remove it from the case.
  20. HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: paso 20, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: paso 20, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: paso 20, imagen 3 de 3
    • Disconnect all the ribbon cables from the motherboard.
    • Ensure to flip up the locking flaps before attempting to pull the ribbon out.
  21. HP 15-dy2702dx Keyboard Replacement: paso 21, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 21, imagen 2 de 2
    • Continue disconnecting the ribbon cables.
  22. HP 15-dy2702dx Keyboard Replacement: paso 22, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 22, imagen 2 de 2
    • Continue disconnecting the remaining ribbons.
  23. HP 15-dy2702dx Keyboard Replacement: paso 23, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 23, imagen 2 de 2
    • Disconnect the connector.
  24. HP 15-dy2702dx Keyboard Replacement: paso 24, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 24, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 24, imagen 3 de 3
    • Peel off the black sticker covering the silver connectors near the top of the motherboard.
    • Remove the two silver colored round connector from the motherboard by pulling them up.
    • The connector should have a tag on them with number 1 and 2 on them.
  25. HP 15-dy2702dx Keyboard Replacement: paso 25, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 25, imagen 2 de 2
    • Pull up on the last connector on the motherboard next to the connectors removed in the previous step.
  26. HP 15-dy2702dx Keyboard Replacement: paso 26, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 26, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 26, imagen 3 de 3
    • Unscrew all M2x3 Phillips screws holding the motherboard in place.
  27. HP 15-dy2702dx Keyboard Replacement: paso 27, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 27, imagen 2 de 2
    • Remove the motherboard from the case.
  28. HP 15-dy2702dx Keyboard Replacement: paso 28, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 28, imagen 2 de 2
    • Unscrew the two M2x3 Phillips screws.
    • Remove the I/O board from the case.
  29. HP 15-dy2702dx Keyboard Replacement: paso 29, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 29, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 29, imagen 3 de 3
    • Unscrew the three M2x6 Phillips screws from the left metal hinge.
    • Lift the hinge.
  30. HP 15-dy2702dx Keyboard Replacement: paso 30, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 30, imagen 2 de 2
    • Unscrew the two Phillips screws.
    • One is on the left side near where the fan was removed.
    • The other is near the right laptop metal hinge.
  31. HP 15-dy2702dx Keyboard Replacement: paso 31, imagen 1 de 2 HP 15-dy2702dx Keyboard Replacement: paso 31, imagen 2 de 2
    • Remove the black boxes from the case.
    • Disconnect the power cable (white cable with a black flag at the end).
    • The black boxes is still connected to the case through a black wire, do not attempt to remove the wire.
  32. HP 15-dy2702dx Keyboard Replacement: paso 32, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 32, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 32, imagen 3 de 3
    • Unscrew the three screws on the right-side metal hinge.
    • Lift the hinge.
  33. HP 15-dy2702dx Keyboard Replacement: paso 33, imagen 1 de 1
    • Remove the power port from the case by pulling it straight up.
  34. HP 15-dy2702dx Keyboard Replacement: paso 34, imagen 1 de 3 HP 15-dy2702dx Keyboard Replacement: paso 34, imagen 2 de 3 HP 15-dy2702dx Keyboard Replacement: paso 34, imagen 3 de 3
    • Remove the keyboard from the laptop.
    • The keyboard is a type where it is directly integrated into the frame so you will need to replace the whole frame.
Conclusión
Zander Herbold
Miembro Desde 09/05/23
646 Reputación
4 Guías creadas
Equipo
Gateway, Team 1-4, Pee Fall 2023 Miembro de Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 34
Todo El Tiempo: 208
