Saltar al contenido principal
HP 15-dy2024nr Display Assembly Replacement
Qué necesitas
  1. HP 15-dy2024nr Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 HP 15-dy2024nr Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    • Peel the inner edge of the bezel using an opening tool and gently snap both edges away from the glass.
    • Go around the perimeter and begin snapping the tabs underneath.
  2. HP 15-dy2024nr Display Assembly Replacement: paso 2, imagen 1 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 2, imagen 2 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 2, imagen 3 de 3
    • Use the opening tool to unsnap the bezel along the hinge cover.
    • Close the laptop and turn it sideways.
    • Separate the bezel along the bottom edge using the opening tool.
    • Remove the bezel and place it aside.
  3. HP 15-dy2024nr Display Assembly Replacement: paso 3, imagen 1 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 3, imagen 2 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 3, imagen 3 de 3
    • Remove the 1.8 mm screws from the top and bottom corners of the screen using a Phillips #1 screwdriver.
    • Use a pair of tweezers to pull out the adhesive tape from the bottom left and right corners of the screen.
    • Remove the LCD and gently place it on the keyboard with both hands.
  4. HP 15-dy2024nr Display Assembly Replacement: paso 4, imagen 1 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 4, imagen 2 de 3 HP 15-dy2024nr Display Assembly Replacement: paso 4, imagen 3 de 3
    • Gently peel off the tape securing the video connector.
    • Disconnect the video cable.
    • Remove the old screen.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 50
Todo El Tiempo: 121
