Saltar al contenido principal
HP 15-dy2024nr Back Cover Replacement
Qué necesitas
  1. HP 15-dy2024nr Back Cover Replacement, Back Cover: paso 1, imagen 1 de 2 HP 15-dy2024nr Back Cover Replacement, Back Cover: paso 1, imagen 2 de 2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Back Cover Replacement: paso 2, imagen 1 de 3 HP 15-dy2024nr Back Cover Replacement: paso 2, imagen 2 de 3 HP 15-dy2024nr Back Cover Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Back Cover Replacement: paso 3, imagen 1 de 3 HP 15-dy2024nr Back Cover Replacement: paso 3, imagen 2 de 3 HP 15-dy2024nr Back Cover Replacement: paso 3, imagen 3 de 3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
Conclusión
Una persona más ha completado esta guía.
Konnor Young
Miembro Desde 09/27/22
523 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 46
Todo El Tiempo: 949
