Saltar al contenido principal
HP 15-db0015dx WLAN Module Replacement
Qué necesitas
  1. HP 15-db0015dx WLAN Module Replacement, Battery: paso 1, imagen 1 de 2 HP 15-db0015dx WLAN Module Replacement, Battery: paso 1, imagen 2 de 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx WLAN Module Replacement: paso 2, imagen 1 de 3 HP 15-db0015dx WLAN Module Replacement: paso 2, imagen 2 de 3 HP 15-db0015dx WLAN Module Replacement: paso 2, imagen 3 de 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx WLAN Module Replacement: paso 3, imagen 1 de 3 HP 15-db0015dx WLAN Module Replacement: paso 3, imagen 2 de 3 HP 15-db0015dx WLAN Module Replacement: paso 3, imagen 3 de 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx WLAN Module Replacement, WLAN Module: paso 4, imagen 1 de 1
    • Disconnect the wire attached to the WLAN card by prying it upward from the card.
  5. HP 15-db0015dx WLAN Module Replacement: paso 5, imagen 1 de 1
    • Remove the screw holding down the card with a Phillips #0 screwdriver.
  6. HP 15-db0015dx WLAN Module Replacement: paso 6, imagen 1 de 2 HP 15-db0015dx WLAN Module Replacement: paso 6, imagen 2 de 2
    • Pull the WLAN Module out of the connection port.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 462
