Saltar al contenido principal
HP 15-db0015dx Hard Drive Replacement
Qué necesitas
  1. HP 15-db0015dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 HP 15-db0015dx Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx Hard Drive Replacement: paso 2, imagen 1 de 3 HP 15-db0015dx Hard Drive Replacement: paso 2, imagen 2 de 3 HP 15-db0015dx Hard Drive Replacement: paso 2, imagen 3 de 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx Hard Drive Replacement: paso 3, imagen 1 de 3 HP 15-db0015dx Hard Drive Replacement: paso 3, imagen 2 de 3 HP 15-db0015dx Hard Drive Replacement: paso 3, imagen 3 de 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 HP 15-db0015dx Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 HP 15-db0015dx Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
    • Pull the hard drive bracket out.
  5. HP 15-db0015dx Hard Drive Replacement: paso 5, imagen 1 de 1
    • Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 61
Todo El Tiempo: 3,943
