Saltar al contenido principal
HP 15-db0004dx Battery Replacement
Qué necesitas
  1. HP 15-db0004dx Battery Replacement, Bottom Case: paso 1, imagen 1 de 2 HP 15-db0004dx Battery Replacement, Bottom Case: paso 1, imagen 2 de 2
    • Turn the laptop off and unplug it before starting.
    • Flip your laptop over, face down.
  2. HP 15-db0004dx Battery Replacement: paso 2, imagen 1 de 1
    • Peel off the two long rubber grips running lengthwise on the laptop.
  3. HP 15-db0004dx Battery Replacement: paso 3, imagen 1 de 2 HP 15-db0004dx Battery Replacement: paso 3, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
  4. HP 15-db0004dx Battery Replacement: paso 4, imagen 1 de 1
    • Carefully slide the optical drive out of the laptop.
  5. HP 15-db0004dx Battery Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to separate the back panel from the laptop.
    • For an easier removal, start at the corner and run the tool along the edge of the cover.
    • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
    • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
  6. HP 15-db0004dx Battery Replacement, Battery: paso 6, imagen 1 de 2 HP 15-db0004dx Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Using the Philips #000 screwdriver remove all of the six 5mm screws.
  7. HP 15-db0004dx Battery Replacement: paso 7, imagen 1 de 3 HP 15-db0004dx Battery Replacement: paso 7, imagen 2 de 3 HP 15-db0004dx Battery Replacement: paso 7, imagen 3 de 3
    • Disconnect the battery connector.
    • Slide the battery up and out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 643
