Saltar al contenido principal
HP 15-da0012dx RAM Replacement
Qué necesitas
  1. HP 15-da0012dx RAM Replacement, Battery: paso 1, imagen 1 de 2 HP 15-da0012dx RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx RAM Replacement: paso 2, imagen 1 de 3 HP 15-da0012dx RAM Replacement: paso 2, imagen 2 de 3 HP 15-da0012dx RAM Replacement: paso 2, imagen 3 de 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx RAM Replacement: paso 3, imagen 1 de 2 HP 15-da0012dx RAM Replacement: paso 3, imagen 2 de 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx RAM Replacement: paso 4, imagen 1 de 2 HP 15-da0012dx RAM Replacement: paso 4, imagen 2 de 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx RAM Replacement: paso 5, imagen 1 de 3 HP 15-da0012dx RAM Replacement: paso 5, imagen 2 de 3 HP 15-da0012dx RAM Replacement: paso 5, imagen 3 de 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx RAM Replacement: paso 6, imagen 1 de 2 HP 15-da0012dx RAM Replacement: paso 6, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx RAM Replacement: paso 7, imagen 1 de 2 HP 15-da0012dx RAM Replacement: paso 7, imagen 2 de 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx RAM Replacement, RAM: paso 8, imagen 1 de 2 HP 15-da0012dx RAM Replacement, RAM: paso 8, imagen 2 de 2
    • Spread the retention clips on either side of the RAM module outward until you hear a click sound.
    • The RAM module should tilt up at a 45 degree angle.
  9. HP 15-da0012dx RAM Replacement: paso 9, imagen 1 de 2 HP 15-da0012dx RAM Replacement: paso 9, imagen 2 de 2
    • Grasp the edge of the RAM module and pull it away from the slot.
    • Follow Steps 8 and 9 to remove both RAM modules.
Conclusión
4 personas más completaron esta guía.
Xavier Hung
Miembro Desde 02/07/19
914 Reputación
4 Guías creadas
Equipo
UC Davis, Team S20-G4, Lore Winter 2019 Miembro de UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 2,219
