Saltar al contenido principal
HP 15-da0002dx Fan Replacement
Qué necesitas
  1. HP 15-da0002dx Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Fan Replacement: paso 2, imagen 1 de 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Fan Replacement: paso 3, imagen 1 de 2 HP 15-da0002dx Fan Replacement: paso 3, imagen 2 de 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Fan Replacement: paso 4, imagen 1 de 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Fan Replacement: paso 5, imagen 1 de 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Fan Replacement: paso 6, imagen 1 de 2 HP 15-da0002dx Fan Replacement: paso 6, imagen 2 de 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Fan Replacement: paso 7, imagen 1 de 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Fan Replacement, Battery: paso 8, imagen 1 de 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Fan Replacement: paso 9, imagen 1 de 2 HP 15-da0002dx Fan Replacement: paso 9, imagen 2 de 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx Fan Replacement, Fan: paso 10, imagen 1 de 2 HP 15-da0002dx Fan Replacement, Fan: paso 10, imagen 2 de 2
    • Hold the fan in place and remove the one 8.0 mm screw from the fan .
  11. HP 15-da0002dx Fan Replacement: paso 11, imagen 1 de 1
    • Pull out the connector for the fan cable using the opening tool or spudger.
  12. HP 15-da0002dx Fan Replacement: paso 12, imagen 1 de 1
    • Carefully take out the fan from the computer.
Conclusión
Una persona más ha completado esta guía.
Abigail Aron
Miembro Desde 09/04/19
1,097 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 25
Todo El Tiempo: 1,510
