Saltar al contenido principal
HP 15-d076nr Wireless Card Replacement
Qué necesitas
  1. HP 15-d076nr Wireless Card Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Wireless Card Replacement: paso 2, imagen 1 de 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Wireless Card Replacement: paso 3, imagen 1 de 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Wireless Card Replacement: paso 4, imagen 1 de 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
  5. HP 15-d076nr Wireless Card Replacement, Wireless Card: paso 5, imagen 1 de 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
  6. HP 15-d076nr Wireless Card Replacement: paso 6, imagen 1 de 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  7. HP 15-d076nr Wireless Card Replacement: paso 7, imagen 1 de 2 HP 15-d076nr Wireless Card Replacement: paso 7, imagen 2 de 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  8. HP 15-d076nr Wireless Card Replacement: paso 8, imagen 1 de 2 HP 15-d076nr Wireless Card Replacement: paso 8, imagen 2 de 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
  9. HP 15-d076nr Wireless Card Replacement: paso 9, imagen 1 de 3 HP 15-d076nr Wireless Card Replacement: paso 9, imagen 2 de 3 HP 15-d076nr Wireless Card Replacement: paso 9, imagen 3 de 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
  10. HP 15-d076nr Wireless Card Replacement: paso 10, imagen 1 de 1
    • Slide the wireless card to the left to remove it from the socket.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 557
