Saltar al contenido principal
HP 15-d076nr RAM Replacement
Qué necesitas
  1. HP 15-d076nr RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces away from you.
  2. HP 15-d076nr RAM Replacement: paso 2, imagen 1 de 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  3. HP 15-d076nr RAM Replacement: paso 3, imagen 1 de 2 HP 15-d076nr RAM Replacement: paso 3, imagen 2 de 2
    • Carefully pry the middle panel up using a plastic spudger or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  4. HP 15-d076nr RAM Replacement: paso 4, imagen 1 de 1
    • Locate the RAM in the exposed area.
  5. HP 15-d076nr RAM Replacement: paso 5, imagen 1 de 3 HP 15-d076nr RAM Replacement: paso 5, imagen 2 de 3 HP 15-d076nr RAM Replacement: paso 5, imagen 3 de 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  6. HP 15-d076nr RAM Replacement: paso 6, imagen 1 de 1
    • Remove the RAM.
Conclusión
Amy Weed
Miembro Desde 01/12/17
577 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 574
