Saltar al contenido principal
HP 15-d076nr Fan Replacement
Qué necesitas
  1. HP 15-d076nr Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
    • Locate the left and right switches at the bottom of the laptop.
  2. HP 15-d076nr Fan Replacement: paso 2, imagen 1 de 1
    • Move the right switch to the left so that the orange unlock symbol is showing.
  3. HP 15-d076nr Fan Replacement: paso 3, imagen 1 de 1
    • Move the left switch to the right, covering the battery symbol, and hold.
  4. HP 15-d076nr Fan Replacement: paso 4, imagen 1 de 1
    • While holding the left switch in place, slide the battery towards you and away from the laptop.
  5. HP 15-d076nr Fan Replacement, Wireless Card: paso 5, imagen 1 de 1
    • Re-orient the laptop, so that the back of the laptop faces away from you.
  6. HP 15-d076nr Fan Replacement: paso 6, imagen 1 de 1
    • Locate the small screw on the panel at the center of the laptop.
    • Loosen the small screw using a Philips # 1 screwdriver.
    • The screw does not come free from the panel. It only needs to be loosened enough so that the panel can be lifted/pried.
  7. HP 15-d076nr Fan Replacement: paso 7, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 7, imagen 2 de 2
    • Carefully pry the middle panel up using a plastic spudger, or other prying tool .
    • Pull the panel away from the laptop and set it off to the side.
  8. HP 15-d076nr Fan Replacement: paso 8, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 8, imagen 2 de 2
    • Gently wiggle and lift the black antenna wire away from the wireless card.
    • If there is also a white wire attached, both black and white wires will need to be removed from the wireless card.
  9. HP 15-d076nr Fan Replacement: paso 9, imagen 1 de 3 HP 15-d076nr Fan Replacement: paso 9, imagen 2 de 3 HP 15-d076nr Fan Replacement: paso 9, imagen 3 de 3
    • Locate the Phillips 2.0x3.0mm screw on the upper left corner of the wireless card.
    • Carefully remove the 2.0x3.0mm screw using a Philips #0 screwdriver.
  10. HP 15-d076nr Fan Replacement: paso 10, imagen 1 de 1
    • Slide the wireless card to the left to remove it from the socket.
  11. HP 15-d076nr Fan Replacement, Motherboard: paso 11, imagen 1 de 1
    • Locate the RAM in the exposed area.
  12. HP 15-d076nr Fan Replacement: paso 12, imagen 1 de 3 HP 15-d076nr Fan Replacement: paso 12, imagen 2 de 3 HP 15-d076nr Fan Replacement: paso 12, imagen 3 de 3
    • Locate the latches on the RAM.
    • Slide the latches away from the RAM using a plastic spudger.
    • The RAM might spring out.
  13. HP 15-d076nr Fan Replacement: paso 13, imagen 1 de 1
    • Remove the RAM.
  14. HP 15-d076nr Fan Replacement: paso 14, imagen 1 de 3 HP 15-d076nr Fan Replacement: paso 14, imagen 2 de 3 HP 15-d076nr Fan Replacement: paso 14, imagen 3 de 3
    • Locate the ribbon cables.
    • Pry up the black tabs on the connectors and disconnect both of the ribbon cables.
  15. HP 15-d076nr Fan Replacement: paso 15, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 15, imagen 2 de 2
    • Locate the DVD drive screw.
    • Remove the Phillips PM2.5×6.5 screw using a Phillips #0 screwdriver.
    • Continue using a Phillips #0 screwdriver for the rest of this guide, and subsequent guides.
    • Take the screw and place it in a container so as to not lose it.
  16. HP 15-d076nr Fan Replacement: paso 16, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 16, imagen 2 de 2
    • Push down the tab that is located by the DVD drive screw.
    • Take the DVD drive in one hand, and using the plastic spludger, push the tab down, and out.
  17. HP 15-d076nr Fan Replacement: paso 17, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 17, imagen 2 de 2
    • Remove the fourteen Phillips PM2.5×6.0 screws, and place them in a separate container.
  18. HP 15-d076nr Fan Replacement: paso 18, imagen 1 de 3 HP 15-d076nr Fan Replacement: paso 18, imagen 2 de 3 HP 15-d076nr Fan Replacement: paso 18, imagen 3 de 3
    • Flip the laptop over, and open it as if you were using it.
    • Gently, remove the laptop cover/keyboard from the laptop using the plastic spudger.
    • When you remove the cover/keyboard, the laptop will become top heavy.
  19. HP 15-d076nr Fan Replacement: paso 19, imagen 1 de 1
    • Disconnect the monitor cable, using the plastic spudger, and pry it upwards.
    • Pull the cable from its routing until it is free.
  20. HP 15-d076nr Fan Replacement: paso 20, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 20, imagen 2 de 2
    • Lift the black tabs, and disconnect the three ribbon cables.
    • Disconnect the red-black-white speaker cable located in the lower left corner.
  21. HP 15-d076nr Fan Replacement: paso 21, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 21, imagen 2 de 2
    • Remove the three Phillips PM2.5×4.0 screws on the card reader in the bottom left corner.
    • Place the screws in a separate container.
    • Remove the card reader.
  22. HP 15-d076nr Fan Replacement: paso 22, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 22, imagen 2 de 2
    • Remove the five Phillips PM2.5×5.0 screws on the motherboard.
  23. HP 15-d076nr Fan Replacement: paso 23, imagen 1 de 1
    • Remove the Phillips PM2.5×5.0 screw located on the fan, in the upper right corner.
  24. HP 15-d076nr Fan Replacement: paso 24, imagen 1 de 2 HP 15-d076nr Fan Replacement: paso 24, imagen 2 de 2
    • Carefully lift up the motherboard.
    • Do not completely remove the motherboard. Simply lift it. There is a black cable on the bottom of the motherboard that is anchoring it.
  25. HP 15-d076nr Fan Replacement: paso 25, imagen 1 de 1
    • Locate the cable on the underside of the motherboard, in its lower right corner.
    • Carefully grip the cable, and pull downward to remove it.
  26. HP 15-d076nr Fan Replacement: paso 26, imagen 1 de 1
    • Flip the motherboard over.
  27. HP 15-d076nr Fan Replacement: paso 27, imagen 1 de 1
    • Locate the charge port cable connection point on the motherboard.
    • Grab the charge port cable's connector, and wiggle it to remove it.
    • Set the board off to the side.
  28. HP 15-d076nr Fan Replacement, Fan: paso 28, imagen 1 de 2 HP 15-d076nr Fan Replacement, Fan: paso 28, imagen 2 de 2
    • Carefully loosen the four screws on the processor heat sink.
    • The screws do not come out. They are retained by the heat sink.
  29. HP 15-d076nr Fan Replacement: paso 29, imagen 1 de 1
    • Disconnect the red-yellow-blue-black cable, next to the fan, on the motherboard.
    • You may need to wiggle it
  30. HP 15-d076nr Fan Replacement: paso 30, imagen 1 de 1
    • Remove the fan.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 649
