Introducción
This guide details how to replace the charge port on an HP 15-d076nr. If your laptop is not charging, this may be the guide for you.
Qué necesitas
Orient the laptop upside down so that the back of the laptop, where the battery is located, faces you.
Locate the left and right switches at the bottom of the laptop.
Re-orient the laptop, so that the back of the laptop faces away from you.
Unscrew the two screws located in the upper left corner, and the three screws in the upper right, on the metal hinges of the monitor.
Una persona más ha completado esta guía.
2 comentarios
Thanks for a detailed insight on charging port replacement. I was going for a charging port replacement for my HP Pavillion laptop because it was not charging when plugged in. Then I come across this guide, and I removed the battery to reset the power controller module and updated the Microsoft ACPI Compliant Control Method Battery driver, and it started charging.
Your guide is really helpful and step-by-step. Thank you once again.
Thank you detailing charging port replacement. I really learn many thing from your blog helping. From your guide i replace my laptop battery step by step.I remove my laptop battery clean pots and update driver or its start charging.
