Saltar al contenido principal
HP 15-bs080wm Hard Drive Replacement
Qué necesitas
  1. HP 15-bs080wm Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement, Hard Drive: paso 1, imagen 3 de 3
    • Power off the laptop.
    • Do not proceed until both power lights are off.
  2. HP 15-bs080wm Hard Drive Replacement: paso 2, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 2, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 2, imagen 3 de 3
    • Slide the battery lock to the unlock position..
    • Slide the battery release inwards to remove the battery.
  3. HP 15-bs080wm Hard Drive Replacement: paso 3, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 3, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 3, imagen 3 de 3
    • Use the plastic opening tool to remove the four rubber feet.
  4. HP 15-bs080wm Hard Drive Replacement: paso 4, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 4, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the center screw from the back of the laptop using a Phillips #000 screwdriver.
    • Remove the optical drive.
  5. HP 15-bs080wm Hard Drive Replacement: paso 5, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 5, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 5, imagen 3 de 3
    • Remove the nine screws from the back of the laptop using a Phillips #000 screwdriver.
  6. HP 15-bs080wm Hard Drive Replacement: paso 6, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 6, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 6, imagen 3 de 3
    • Use the plastic opening tool to wedge the back plate from the body of the laptop.
    • Flip the laptop over and remove the back plate.
    • Use the opening tool around the entire perimeter of the laptop's base.
  7. HP 15-bs080wm Hard Drive Replacement: paso 7, imagen 1 de 3 HP 15-bs080wm Hard Drive Replacement: paso 7, imagen 2 de 3 HP 15-bs080wm Hard Drive Replacement: paso 7, imagen 3 de 3
    • Remove the three screws from the hard drive bracket using a Phillips #000 screwdriver.
    • Remove the bracket.
    • Slide the hard drive the left to remove it from the socket.
Conclusión
Landon Dickerson
Miembro Desde 02/22/22
195 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 592
