Introducción
This is a guide for replacing the screen for the HP 15-bs051od. Possible reasons to replace the screen include the computer screen is unresponsive, and/or looks frozen.
Note: Our model does not include a battery. Before performing any repair ensure the battery has been removed and the computer is not connected to a power source. It is also important to ground yourself by touching metal to discharge excess electricity before beginning the repair.
Qué necesitas
Start with the laptop face down.
Remove the eight 6 mm Phillips head screws securing the lower case.
Remove the four (4 mm) Phillips screws on the heatsink.
Remove the exhaust by carefully lifting it up.
Remove the following Phillips screws:
Five 7 mm screws on the display hinge.
One 3 mm screw.
