Saltar al contenido principal
HP 15-ay114cy Screen Replacement
Qué necesitas
  1. HP 15-ay114cy Screen Replacement, Orient the Laptop: paso 1, imagen 1 de 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Screen Replacement, Push out the Battery: paso 2, imagen 1 de 2 HP 15-ay114cy Screen Replacement, Push out the Battery: paso 2, imagen 2 de 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Screen Replacement, Remove the Battery: paso 3, imagen 1 de 2 HP 15-ay114cy Screen Replacement, Remove the Battery: paso 3, imagen 2 de 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: paso 4, imagen 1 de 2 HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: paso 4, imagen 2 de 2
    • Insert the flat end of the plastic opening tool between the screen and plastic frame.
    • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
  5. HP 15-ay114cy Screen Replacement, Remove the Screen: paso 5, imagen 1 de 3 HP 15-ay114cy Screen Replacement, Remove the Screen: paso 5, imagen 2 de 3 HP 15-ay114cy Screen Replacement, Remove the Screen: paso 5, imagen 3 de 3
    • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
  6. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: paso 6, imagen 1 de 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: paso 6, imagen 2 de 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: paso 6, imagen 3 de 3
    • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
Conclusión
Bradley Evans
Miembro Desde 01/24/20
613 Reputación
5 Guías creadas
Equipo
S20S3G#1 Miembro de S20S3G#1
Local Repair Groups
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 321
