Saltar al contenido principal
HP 15-ay091ms Optical Disk Drive Replacement
Qué necesitas
  1. HP 15-ay091ms Optical Disk Drive Replacement, Battery: paso 1, imagen 1 de 2 HP 15-ay091ms Optical Disk Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Ensure the device is powered off and is disconnected from any AC power supply.
    • Push the latches on either side of the battery down and outward.
    • This unlatches the battery allowing for easy removal.
    • Remove the battery.
  2. HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: paso 2, imagen 1 de 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: paso 2, imagen 2 de 3 HP 15-ay091ms Optical Disk Drive Replacement, Back Panel: paso 2, imagen 3 de 3
    • Remove the screws from the bottom panel using a JIS #0 screwdriver.
    • Use the iFixit opening pick to lift the back cover from the device.
    • It is helpful to get an opening in one spot of the back cover and carry that opening around the device.
  3. HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: paso 3, imagen 1 de 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: paso 3, imagen 2 de 3 HP 15-ay091ms Optical Disk Drive Replacement, Optical Disk Drive: paso 3, imagen 3 de 3
    • Remove the screws holding the optical drive in place using a JIS #0 screwdriver.
    • Pull the optical disk drive out of its slot.
Conclusión
Jossel Solis
Miembro Desde 09/07/23
173 Reputación
1 Guía escrita
Equipo
Gateway, Team A-1, Gonzalez Fall 2023 Miembro de Gateway, Team A-1, Gonzalez Fall 2023
GCC-GONZALEZ-F23SAG1
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 85
