Saltar al contenido principal
HP 15-ay052nr Motherboard Replacement
Qué necesitas
  1. HP 15-ay052nr Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Motherboard Replacement: paso 2, imagen 1 de 1
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Motherboard Replacement: paso 3, imagen 1 de 1
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Motherboard Replacement, Bottom Cover: paso 4, imagen 1 de 1
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Motherboard Replacement: paso 5, imagen 1 de 1
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Motherboard Replacement: paso 6, imagen 1 de 1
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Motherboard Replacement: paso 7, imagen 1 de 1
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Motherboard Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
  9. HP 15-ay052nr Motherboard Replacement: paso 9, imagen 1 de 1
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
  10. HP 15-ay052nr Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Remove the three 3 mm JIS #0 screws from the hard drive.
  11. HP 15-ay052nr Motherboard Replacement: paso 11, imagen 1 de 1
    • Unplug the hard drive from the motherboard.
  12. HP 15-ay052nr Motherboard Replacement: paso 12, imagen 1 de 1
    • Unplug display from the motherboard.
    • The connection is under a sealing sticker; peel up the sticker to unplug the connection.
  13. HP 15-ay052nr Motherboard Replacement: paso 13, imagen 1 de 1
    • Unplug the power port from the motherboard.
  14. HP 15-ay052nr Motherboard Replacement: paso 14, imagen 1 de 1
    • Unplug the display wire from the wireless adapter.
  15. HP 15-ay052nr Motherboard Replacement: paso 15, imagen 1 de 1
    • Remove the single screw from the wireless card and gently remove the drive.
  16. HP 15-ay052nr Motherboard Replacement: paso 16, imagen 1 de 1
    • Unplug the keyboard from the motherboard.
  17. HP 15-ay052nr Motherboard Replacement: paso 17, imagen 1 de 1
    • Unplug the optical drive connection from the motherboard.
  18. HP 15-ay052nr Motherboard Replacement: paso 18, imagen 1 de 1
    • Remove the memory chip from the motherboard by pushing the clips away from the chip.
    • The chip will pop out once the clips are pulled far enough apart.
    • This is to access the touch-pad wires.
  19. HP 15-ay052nr Motherboard Replacement: paso 19, imagen 1 de 1
    • Unplug both (2) wires for the touch-pad from the motherboard.
  20. HP 15-ay052nr Motherboard Replacement: paso 20, imagen 1 de 1
    • Unplug the speakers from the motherboard.
  21. HP 15-ay052nr Motherboard Replacement: paso 21, imagen 1 de 1
    • Unplug the power button from the motherboard.
  22. HP 15-ay052nr Motherboard Replacement: paso 22, imagen 1 de 1
    • Unscrew the four 3mm JIS #0 screws that secure the motherboard.
    • Once all the screws are removed, the motherboard can be removed by simply lifting it up.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 594
