Saltar al contenido principal
HP 15-ay014dx RAM Replacement
Qué necesitas
  1. HP 15-ay014dx RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx RAM Replacement: paso 2, imagen 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx RAM Replacement: paso 3, imagen 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx RAM Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx RAM Replacement: paso 5, imagen 1 de 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx RAM Replacement, RAM: paso 6, imagen 1 de 1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx RAM Replacement: paso 7, imagen 1 de 2 HP 15-ay014dx RAM Replacement: paso 7, imagen 2 de 2
    • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  8. HP 15-ay014dx RAM Replacement: paso 8, imagen 1 de 2 HP 15-ay014dx RAM Replacement: paso 8, imagen 2 de 2
    • Undo the clips holding the RAM in place using the plastic opening tool.
  9. HP 15-ay014dx RAM Replacement: paso 9, imagen 1 de 1
    • Carefully pull out the RAM from the motherboard.
Conclusión
7 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 727
