Saltar al contenido principal
HP 15-ay014dx Hard Drive Disk Replacement
Qué necesitas
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: paso 1, imagen 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: paso 2, imagen 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: paso 3, imagen 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: paso 5, imagen 1 de 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: paso 6, imagen 1 de 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: paso 6, imagen 2 de 2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: paso 7, imagen 1 de 3 HP 15-ay014dx Hard Drive Disk Replacement: paso 7, imagen 2 de 3 HP 15-ay014dx Hard Drive Disk Replacement: paso 7, imagen 3 de 3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: paso 8, imagen 1 de 3 HP 15-ay014dx Hard Drive Disk Replacement: paso 8, imagen 2 de 3 HP 15-ay014dx Hard Drive Disk Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: paso 9, imagen 1 de 2 HP 15-ay014dx Hard Drive Disk Replacement: paso 9, imagen 2 de 2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: paso 10, imagen 1 de 1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
Conclusión
6 personas más completaron esta guía.
Jimmy Huynh
Miembro Desde 09/26/17
263 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,938
