Saltar al contenido principal
HP 15-ay014dx Battery Replacement
  1. HP 15-ay014dx Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Battery Replacement: paso 2, imagen 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Battery Replacement: paso 3, imagen 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
Conclusión
To reassemble your device, follow these steps in reverse order.
2 personas más completaron esta guía.
Nathan Rapalus
Miembro Desde 09/21/17
137 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 791
