Saltar al contenido principal
HP 15-af013cl Motherboard Replacement
Qué necesitas
  1. HP 15-af013cl Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Motherboard Replacement: paso 2, imagen 1 de 3 HP 15-af013cl Motherboard Replacement: paso 2, imagen 2 de 3 HP 15-af013cl Motherboard Replacement: paso 2, imagen 3 de 3
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Motherboard Replacement, Motherboard: paso 3, imagen 1 de 1
    • Using the Phillips P0 screwdriver, remove the nine 2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional two 2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Motherboard Replacement: paso 4, imagen 1 de 2 HP 15-af013cl Motherboard Replacement: paso 4, imagen 2 de 2
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Motherboard Replacement: paso 5, imagen 1 de 1
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  6. HP 15-af013cl Motherboard Replacement: paso 6, imagen 1 de 2 HP 15-af013cl Motherboard Replacement: paso 6, imagen 2 de 2
    • Begin by removing the 3 Phillips M2.0mm × 10.0mm screws of the processor fan.
    • Disconnect the fan connector from the motherboard.
  7. HP 15-af013cl Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the five Phillips 2.5mm × 6 .5mm screws using the Phillips P0 screwdriver.
  8. HP 15-af013cl Motherboard Replacement: paso 8, imagen 1 de 3 HP 15-af013cl Motherboard Replacement: paso 8, imagen 2 de 3 HP 15-af013cl Motherboard Replacement: paso 8, imagen 3 de 3
    • Disconnect the ribbon cables for the keyboard, display, trackpad and the various system components.
    • Remove the Wi-Fi card and cables.
  9. HP 15-af013cl Motherboard Replacement: paso 9, imagen 1 de 1
    • Carefully lift out the motherboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Stephen Perreira
Miembro Desde 09/27/17
787 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S8-G6, Banghart Fall 2017 Miembro de Cal Poly, Team S8-G6, Banghart Fall 2017
CPSU-BANGHART-F17S8G6
5 Miembros
6 Guías creadas
Un comentario
i need motherboard hp model:15-bs127ne
elbetel ashenafi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 23
Todo El Tiempo: 1,986
