Saltar al contenido principal
HP 15-ac142dx Motherboard Battery Replacement
Qué necesitas
  1. HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: paso 1, imagen 1 de 3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: paso 1, imagen 2 de 3 HP 15-ac142dx Motherboard Battery Replacement, Motherboard Battery: paso 1, imagen 3 de 3
    • Turn off the computer and flip it over onto a flat surface.
    • Remove battery by sliding the battery lock.
    • Remove the 10 screws
  2. HP 15-ac142dx Motherboard Battery Replacement: paso 2, imagen 1 de 2 HP 15-ac142dx Motherboard Battery Replacement: paso 2, imagen 2 de 2
    • Flip the computer back over and use the iFixit tool in order to pry the keyboard from the bottom of the computer.
    • Once off you will be able to see the mother board battery.
    • Remove the battery.
    • The battery should be able to be easily removed just by hand
Conclusión
Follow previous instructions in reverse order to reassemble the device .
Una persona más ha completado esta guía.
Nicole Mathieu
Miembro Desde 03/19/18
620 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 12
Todo El Tiempo: 731
