Saltar al contenido principal
HP 15-ac121dx RAM Replacement
Qué necesitas
  1. HP 15-ac121dx RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx RAM Replacement: paso 2, imagen 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx RAM Replacement: paso 3, imagen 1 de 2 HP 15-ac121dx RAM Replacement: paso 3, imagen 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx RAM Replacement: paso 4, imagen 1 de 2 HP 15-ac121dx RAM Replacement: paso 4, imagen 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx RAM Replacement, Back Panel: paso 5, imagen 1 de 2 HP 15-ac121dx RAM Replacement, Back Panel: paso 5, imagen 2 de 2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx RAM Replacement: paso 6, imagen 1 de 1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx RAM Replacement: paso 7, imagen 1 de 1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
  8. HP 15-ac121dx RAM Replacement, RAM: paso 8, imagen 1 de 1
    • With the back panel removed, orient the laptop with the fan located in the bottom left corner.
    • Locate the RAM card.
  9. HP 15-ac121dx RAM Replacement: paso 9, imagen 1 de 2 HP 15-ac121dx RAM Replacement: paso 9, imagen 2 de 2
    • Using your fingers, carefully release the locking devices on both sides of the RAM card by moving them away from each other.
    • The RAM card will pop up to sit at an angle.
    • Carefully remove the RAM card with the same orientation which it sits.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 650
