Saltar al contenido principal
HP 15-ac121dx Motherboard Replacement
Qué necesitas
  1. HP 15-ac121dx Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Motherboard Replacement: paso 2, imagen 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Motherboard Replacement: paso 3, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 3, imagen 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Motherboard Replacement: paso 4, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 4, imagen 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Motherboard Replacement, Back Panel: paso 5, imagen 1 de 3 HP 15-ac121dx Motherboard Replacement, Back Panel: paso 5, imagen 2 de 3 HP 15-ac121dx Motherboard Replacement, Back Panel: paso 5, imagen 3 de 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Motherboard Replacement: paso 7, imagen 1 de 3 HP 15-ac121dx Motherboard Replacement: paso 7, imagen 2 de 3 HP 15-ac121dx Motherboard Replacement: paso 7, imagen 3 de 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Motherboard Replacement, Fan: paso 8, imagen 1 de 3 HP 15-ac121dx Motherboard Replacement, Fan: paso 8, imagen 2 de 3 HP 15-ac121dx Motherboard Replacement, Fan: paso 8, imagen 3 de 3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Motherboard Replacement: paso 9, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 9, imagen 2 de 2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Motherboard Replacement: paso 10, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  11. HP 15-ac121dx Motherboard Replacement, CD Compartment: paso 11, imagen 1 de 3 HP 15-ac121dx Motherboard Replacement, CD Compartment: paso 11, imagen 2 de 3 HP 15-ac121dx Motherboard Replacement, CD Compartment: paso 11, imagen 3 de 3
    • Locate the CD Compartment as shown and gently slide it out.
  12. HP 15-ac121dx Motherboard Replacement, Motherboard: paso 12, imagen 1 de 1
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac121dx Motherboard Replacement: paso 13, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 13, imagen 2 de 2
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac121dx Motherboard Replacement: paso 14, imagen 1 de 2 HP 15-ac121dx Motherboard Replacement: paso 14, imagen 2 de 2
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac121dx Motherboard Replacement: paso 15, imagen 1 de 1
    • Remove the motherboard.
Conclusión
Una persona más ha completado esta guía.
Onose Aigbe
Miembro Desde 01/30/18
390 Reputación
3 Guías creadas
Equipo
Baylor, Team S1-G2, Johnson Spring 2018 Miembro de Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 Miembros
6 Guías creadas
Un comentario
Pls can the motherboard of HP - 15 ac-250g5 replacethe board of HP 15 ac-121dx since they have the same body structure.
Emeka Jeffrey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 1,290
